Playing with registry
Post  sudinem on Fri Nov 07, 2008 10:54 pm
1)Disable Status Messages During Boot, Logon, Logoff, ShutdownStart/Run/RegeditHKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System Right click in the right pane and select New, DWord value. Name the new value DisableStatusMessages. Double click the new value and set it to 1. Status messages will no longer show during boot/shutdown/logon/logoff.
2)Disable Balloon TipsStart/Run/Regedit HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced. Modify or create, "EnableBalloonTips" and set the Value to 0. To restore set the Value to 1.
3)Disable Media Player Update MessageStart/Run/Regedit HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\PlayerUpgrade. Value Name: AskMeAgain, Data Type: REG_SZ (String Value), Value Data: "yes" or "no". Create a new String value, or modify the existing value, called 'AskMeAgain' and edit the value according to the settings below. Exit your registry, you may need to restart or log out of Windows for the change to take effect.
4)Disable/Enable Boot DefragStart/Run/Regedit HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction Select Enable from the list on the right. Right on it and select Modify. Change the value to Y to enable and N to disable. Reboot your computer.
5)Disable the Windows KeyStart/Run/Regedit Create a new Binary value, or modify the existing value, called 'Scancode Map' and edit the value according to the settings below. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\ Keyboard Layout. Value Name: Scancode Map, Data Type: REG_BINARY (Binary Value), Value Data: 00 00 00 00 00 00 00 00 03 00 00 00 00 00 5B E0 00 00 5C E0 00 00 00 00
6)Disable Error ReportingStart/Run/Regedit HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\PCHealth\ErrorReporting. Value: DoReport, 1 = Send Reports, 0 = Don't Send.
7)Disable Crash Control Auto RebootStart/Run/Regedit HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\CrashControl In the right pane, "AutoReboot" set the Value to 1. To disable set the value back to 0.
8)Disable Low Disk Space MessageStart/Run/Regedit HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer. Create or modify: NoLowDiskSpaceChecks REG_DWORD and set the value to 1. Logoff/Reboot.
9)Disable the Thumbnail CacheStart/Run/RegeditHKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\ Explorer\Advanced. Value Name: DisableThumbnailCache, Data Type: REG_DWORD (DWORD Value), Value Data: (0 = enabled, 1 = disable cache). Create a new DWORD value, or modify the existing value, called 'DisableThumbnailCache' and edit the value according to the settings below. Exit your registry, you may need to restart or log out of Windows for the change to take effect
10)Disable/Turn Off System BeepsStart/Run/RegeditHKEY_CURRENT_USER\Control Panel\Sound In the right pane, right click "Beeps", modify, set the value to no. Exit, reboot.
11)Disable/Stop Error Messages When Booting Start/Run/Regedit HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Windows. Value Name: NoPopupsOnBoot, Data Type: REG_DWORD (DWORD Value), Value Data: (1 = disable messages). Stops the annoying Windows pop-up messages notifying you a device is not functioning when you boot-up Windows. Create a REG_DWORD value of 'NoPopupsOnBoot' in the key below (if it doesn't already exist). Set the value to '1' to disable pop-up messages from appearing.
12)Disable Desktop Cleanup Wizard Start/Run/Regedit HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\ Explorer\Desktop\CleanupWiz. Value Name: NoRun, Data Type: REG_DWORD (DWORD Value), Value Data: (0 = enabled, 1= disable wizard). Create a new DWORD value, or modify the existing value, called 'NoRun' and edit the value according to the settings below. Exit your registry, you may need to restart or log out of Windows for the change to take effect.
13)Disable Auto-Run of Windows MessengerStart/Run/RegeditHKEY_CURRENT_USER\SOFTWARE\ MICROSOFT\WINDOWS\CURRENTVERSION\RUN. Delete the Value named MSMSGS.
sudinem
Permissions of this forum:
